mercruiser molded cooling hoses best place to buy
Hey guys,
I want to replace the cooling hoses on my Mercruiser 502 Mag. The hose going from the stat housing to the top of the oil cooler has a slight drip and I want to replace it before failure occurs. I figure while im at it replace them all. Its a late 90's to early 2000's setup with V belts not serp.
I've had good luck with the Wonderflex marine hose.
It's available at most industrial hose or hydraulic suppliers.
As long as there is no built in end to end dia size difference in the custom molded rubber hose.
Wonderflex is wire reinforced.
I've bought tons of parts from this seller:
https://www.ebay.com/itm/271546908748
says in stock. if you need it faster.
i always just google the part # and look for lowest price/fast shipping depending on my boating needs of the day.
