4 port cooling manifold >
Old 08-28-2023 | 01:05 PM
Default 4 port cooling manifold
4 port cooling system on a bbc
anyone tried and tested it ?
Bulitz is offline
Old 08-28-2023 | 11:44 PM
Can you says that again , try english this time and sober .
thanx
ICDEDPPL is offline
Old 08-29-2023 | 01:16 AM
thanx
forgot to upload photos so you can understand
Bulitz is offline
Old 08-29-2023 | 05:23 AM
Ideal method of engine cooling for most consistent temps
Some related info from another thread
getrdunn is offline
Old 08-29-2023 | 08:32 PM
SB
Yup. Many run those lines.
SB is offline
Old 08-29-2023 | 10:37 PM
I thought the backs were for steam pockets .. not sure I like that
ICDEDPPL is offline
Old 08-30-2023 | 12:46 AM
I am not sure if the back lines work or not I think they disturb the flow.
I read on another forum that Diamond Performance throw the pipes coming rear intake into the exhaust headers which it makes more sense .
has anyone tried this setup ?
Bulitz1 is offline
Old 08-30-2023 | 09:48 AM
Are you saying they use the rear intake manifold ports to dump the water and cool the exhaust?
Makes sense to me in one way although I’d think the header temps would be quite hot. Maybe not enough notice. Idk
getrdunn is offline
Old 08-30-2023 | 12:59 PM
Someone did it ? It works ?
Bulitz is offline
Old 08-30-2023 | 01:10 PM
BBYSTWY's Avatar
I just run dumps on mine....from the rear of the intake where those are dumped overboard through the transom....helps keep the rear cylinder temps consistent and gets rid of steam pockets as Dan said.
BBYSTWY is offline
