Mercruiser Trim Pumps (Pre Alpha to ?)
Hey guys, I have a 78 Sleekcraft with a Mercruiser 260. Well, 2 weeks ago, the trim pump quit working. No, it's not the solenoid, that still clicks fine, and I tried jumping the motor with a healthy piece of wire, no dice. It looked like this:
Anyway, wanting to hit the water this weekend, I picked this up locally:
Same # of wires, same colors wires, and only 2 ports, one must be high pressure and one low pressure, right?
Well, I wired it all up so it was identical to my original one, and it works! Sort of. It trims at like 4x speed, and when I trimmed down, it blew the seals on the reverse trim lockout switch thing. Why did it do this? I don't understand, a trim pump should be a trim pump, right? Is it just moving way more fluid than the old one? If so, wtf kind of trim rams did that have? I don't understand what I did wrong here.
