92 38 fever >
92 38 fever
92 38 fever
Old 09-15-2023 | 02:54 PM
Default 92 38 fever
hi guys new to a fountain i juss purchased a 92 fever 38 with 502's and bravo 1s its a solid boat stringer and transom wise is there any other problem i should look out for
wallman is offline
Old 09-16-2023 | 08:11 AM
Active Streak: 30 Days
502 Mags? Hour's? All stock motor's? Run it like you stole it.
Helmwurst is offline
Old 09-16-2023 | 10:57 AM
Yea 502 mags all stock around 500 hrs on em the boat runs great
wallman is offline
Old 11-01-2023 | 06:24 PM
Remove bumper strip at rear of swim platform and see if the gap between the top and bottom hull halfs are still sealed. My 1990 27/29' model had shrunk sealant and water would leak in when launching from trailer. Discovered this on mine when boat was backed into the water and rear of swim platform was submerged. Saw water coming into bilge thru small holes in transom (on both sides of bilge). Common issue on older boats.
zz28zz is offline
Old 12-01-2023 | 07:54 AM
Default .
Derek is this you?
87CigCafe is offline
