Part # ?
These fittings go to the water pressure gauge and water pressure fitting in the block on my 29’ Fountain. Does anybody have a part number for them? I’m trying to replace them because as you can see, they are a bit raggity.
TIA
Not sure the size of yours but that type fitting is “
You can get these many places. Just need the size. 1/8 “ ? 1/4” ? 3/8 “?
Push On Hose Barb X Female 37 Degree JIC Flare Swivel Brass Fittings”
Thank you very much. FWIW. I used a 9/16 wrench to remove. So maybe ID is 1/4”?
