will MSD 8222 coil work with merc TB5 system >
Old 10-03-2023 | 04:17 PM
Default will MSD 8222 coil work with merc TB5 system
Doing a full tune up on my 1995 7.4 Merc, with TBV ignition. Wondering if the MSD 8222 coil (High Vibration) work with the TBV system? I see the primary resistance is within spec (0.7ohms) but the secondary on the msd is 4.5k - spec is 9,400-11,700 Ohms.
MSD coil is much cheaper than stock replacements, plus i'm finding that some of the "direct replacements" are not within primary spec upon a closer look.
I've tried asking this on other forums, but some of the marine community tends to be anti-aftermarket, and against the replacing of parts. No it's not broken but I like keeping components fresh. Thanks in advance.
echo23 is offline
Old 10-03-2023 | 10:24 PM
SB
Yes it works. Have several in the field. One is going on 18 yrs or so.
You can search this topic and i’ve chined in and discussed this a lot over the last 20yrs.
SB is offline
