Bigger valves for 781 ovals
Is the original gm hardened seat enough for the exhaust? and if so, what size valve can be used keeping the seat hardened.
Some say you need to use additives with these old heads, and some say it is bull$$.
5/16” pushrods?
Stock valves?
equals disaster but considering that’s not your question I won’t go there. However valves and seats are crucial regardless of additives etc. I know making the power with your heads isn’t a big deal but making it last is. If heads been ported im assuming they’ve been flowed? You’re about peaked out with rpm and “definitely” with lift.
Please provide casting number on heads. A little bit confusing when referring to 781’s and peanut port heads. Entirely different. Just sayin
What casting number on the heads?
5/16” pushrods?
Stock valves?
5/16” pushrods?
Stock valves?
The flow ratio is decent for GM heads. I remember GM heads always liked a bigger split (10-12 deg + -) due to the poor exh etc. If you have a good reliable package I’d call it a day unless you go aftermarket otherwise your gain going to be so minimal I wouldn’t think would be worth all the time, effort and expense. JMO of course.
You are right! I just need to take a account my hole combination of parts. The gm roller lifters might be a problem at higher rpms with max recomended spring pressures 140/380lbs , 230/236 @ 050" cam might pull quite high with good set of heads.
