Rebuild or repower >
Rebuild or repower
Rebuild or repower
Old 11-13-2023 | 04:50 PM
Default Rebuild or repower
I currently have a gen 6 454 mag mpi freshwater Cooled straight inboard with a zf transmission in my 27 conch center console. I'm contemplating having the block rebuilt for around 4500 over the winter and putting all new coolers etc back on. A few people are stating to stay away from rebuilding and just get a new engine. The only engine I have come across in gas with that torque and hp is the ilmor 6.2 gdi. Marine Power has a model but I'm being told parts are tough to come by. The ilmore engine will be around 32k . Just wondering if anyone has had any luck with rebuilds.
thanks
rusty12 is offline
Old 11-13-2023 | 05:28 PM
I would rebuild what you hand if you have a good shop. At least you know what you are getting.
Find out what is included for 4500. Sounds cheap?
Where are you located? Maybe a member can recommend a good rebuilder for you?
underpsi68 is offline
Old 11-13-2023 | 07:33 PM
I'm in southeast mass. I was referred to custom automotive in weymouth ma. Have heatd a lot of good things about them
rusty12 is offline
Old 11-13-2023 | 09:02 PM
What is wrong with your present engine that you think it needs rebuilding ? How many hours ? I would be a little leery of anyone who says they can do one of those correctly for $4500. I can look up some parts prices to be sure but i would expect closer to $7000 Does Mercruiser offer a reman for your engine ?
BillK is offline
Old 11-13-2023 | 09:07 PM
Currently 2700 hours. I do manifolds and risers every 4-5 years and keep up on all the maintenance. I commercial fish with this boat so I'd rather do it over the winter than deal with it during the season. It's running great but I know the day is coming with the hours. No I can't get a gen vi 454 block otherwise I would
rusty12 is offline
Old 11-13-2023 | 09:31 PM
I would say you got your moneys worth out of it I have a nice 2000 Gen6 454 at the shop that would be a nice foundation but I am in Maryland. You might want to try and find one up closer to you and have it built and ready to swap over.
BillK is offline
Old 11-13-2023 | 10:23 PM
Is the block you have freshwater Cooled? I have looked all over up my way haven't been able to find anything
rusty12 is offline
Old 11-14-2023 | 03:01 AM
Gen VI blocks can be elusive, but they are around.
Aftermarket blocks are a good value once you add in the machining costs and used block cost etc.
Tartilla is offline
Old 11-14-2023 | 03:10 AM
Fresh water cooled...I would rebuild. You've proven the combo and setup. Changing anything can create unforseen issues during your working season. 2700 hrs on a mild roller cam...it may still be gtg.
​​Have you done a compression test?
If you did one every season when you do plugs, you have a baseline of how it's doing. Maybe just needs a hone and re-ring and clean up the guides and valve job.
Merc has a very good handle on engine tolerance specs in the shop manuals.
A Gen VI 1999 Merc I just tore down, with 600 hrs had 4.251" bores and cross hatch.
Tartilla is offline
Old 11-14-2023 | 04:37 AM
SB
Commercial fish….SE MASS…new manifolds/risers every 4-5…..sounds like salt water to me…
SB is offline
