39 unlimited 700’s BAM transmission upgrade? >
39 unlimited 700?s BAM transmission upgrade?
Old 11-19-2023 | 09:52 AM
ballon78's Avatar
Default 39 unlimited 700’s BAM transmission upgrade?
I’m thinking about doing the bam transmission upgrade in my 39 I’ve already converted to NXT to number sixes. Is there anyone out there that has done the upgrade in a 39 top gun.
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 11-19-2023 | 10:41 AM
Can't answer from direct experience but Considering you eliminated a hp capacity of the NXT and addressing the limited capacity of the stock trans, keep in mind when buying replacement trans - the Stage 4 kit will turn a stock 700 into 900+ with a bolt on+ reflash.
Sooner or later most engines get a kit of some stage to up the performance
speicher lane is offline
