33AVS real world numbers >
Old 12-28-2023 | 06:47 AM
Default 33AVS real world numbers
Currently been working on a 33AVS project. It’s time to buy power. I originally wanted to build 540’s but with the money that’s already been spent that might have to be down the road. I came across a pair of low hours 496HO’s. Wondering what the performance will be with this power and whats the best props to run? TIA
Mtb_05 is offline
Old 12-30-2023 | 04:14 PM
28b1’s and 74-75
tmmii is offline
Old 12-31-2023 | 01:25 PM
scarabman's Avatar
496 HO's, not HO Mag? Kind of like a Vette with a 4 banger in it.
scarabman is offline
Old 12-31-2023 | 01:33 PM
good catch. My numbers were for mags.
tmmii is offline
Old 12-31-2023 | 01:57 PM
do you know the performance with 496 HO’s 425hp. Not the 375hp mag motors.
Mtb_05 is offline
Old 12-31-2023 | 02:14 PM
Back to the numbers above then. Friend had a 33 with 415hp 502 mag mpi’s. Right at 74 on radar.
tmmii is offline
Old 03-13-2024 | 03:45 PM
My 33 avs 496 HO has seen 82mp/h (gps) on top with basically no fuel/cargo and good chop, it will however run 77-78 anyday of the week no matter the weight, has stock bravo xr drives with stock bravo1 30p props spinning in, freshwater, quite pleased with those numbers!
j_peterson is offline
Old 03-14-2024 | 04:40 AM
articfriends's Avatar
Your turning stock bravo one 30s with 496 hos? how many rpms? Thats pretty impressive. on my 33 w butchered up 28s I saw 77/78 w 500 efis on rev limiter, with labbed 30s I saw 85, with box stock 30s I saw 81/82 ish under best conditions and it struggled to pull past 79/80 mph with them with 500s, Smitty
articfriends is offline
Old 03-14-2024 | 06:30 AM
Rpm is right around 4900, my boat is lighter than standard due to a carbon fibre engine hatch (no sunpad), that saves me around 200 lb, perhaps that's the key to my speed, speed is verified with several different gps;s though.
Entire hatch is 30 lb with gas pistons and latches and you can walk on it no problem!
Old 03-14-2024 | 09:46 AM
Scarabeman,
Don't believe there is such a beast as a "496HO (non MAG)". I believe it's either a "496MAG" or a "496MAG HO". The HO is higher output than the MAG.
Thanks. Brad.
Brad Christy is online now
