Water in engine. Rebuilt 700sci >
Old 02-22-2024 | 09:29 AM
Default Water in engine. Rebuilt 700sci
Hey there
i had a newly rebuilt 700sci. Put it in boat ran without water for 10 seconds engine ran well.
Put the belt for water pump on, connected hose. After two minutes engine hydro locked.
was shocked.
Coolant reservoir empty.
Opening engine Sunday. Would you think it’s from intake , head gasket, or somewhere else.
pressure tested manifolds all is good. they are brand new hardins.
thank you
intimid8 is offline
Old 02-22-2024 | 09:35 AM
Forgot to mention
water mostly in two cylinders
intimid8 is offline
Old 02-22-2024 | 10:45 AM
TomZ's Avatar
Which two cylinders? Rear? Adjacent?
TomZ is offline
Old 02-22-2024 | 11:18 AM
if I’m looking at engine (belt) it is first two on the right side
intimid8 is offline
Old 02-22-2024 | 11:34 AM
F-2 Speedy's Avatar
1 & 3......Id be hunting down the guy who rebuilt it, have you contacted them ? could be head gasket or intake
F-2 Speedy is offline
Old 02-22-2024 | 02:28 PM
Was it fresh water or antifreeze that filled the cylinders? Because you said coolant reservoir was empty, but you tested your manifolds?? The coolant reservoir is antifreeze, and the manifolds are raw water.
I had an engine a couple years ago that would start and run with no hose, but then as soon as a hose was connected it would quit. Ended up being a leaking intercooler.
302Sport is offline
Old 02-22-2024 | 03:19 PM
Originally Posted by intimid8
Forgot to mention
Just went through this same thing at rebuild. The heads are BAD. There is internal corrosion in aluminum BBC heads due to sea water cooling. The heads should have been inspected before working on them. My heads were to the point of trashing them or welding them up around the water passages. It was $1000 to weld them to save them for another year or two.
Long story short the heads/ head gasket is leaking coolant. Weld or replace the heads.
LakeBoat4 is offline
Old 02-22-2024 | 03:31 PM
F-2 Speedy's Avatar
LB4 the 700 SCI is closed cooled like the 525 and 600....so no acid water to deal with
Old 02-22-2024 | 04:18 PM
Your Right, my mistake. Still the leak points to heads and head gasket issues.
Old 02-22-2024 | 07:36 PM
SB
Builder or owner put the intake on ?
SB is offline
