Oil filter relocation seal >
Old 03-12-2024 | 02:04 AM
Default Oil filter relocation seal
I’m having trouble finding this seal. Its like a flat O ring. About 3/16 wide and hi.
Thanks in advance
BigDawgChallenge is offline
Old 03-12-2024 | 05:35 AM
What are the inside and outside diameters?
underpsi68 is offline
Old 03-12-2024 | 06:45 AM
G1K
It should be the same as the gasket that comes on the (stock size) oil filter.
G1K is offline
Old 03-12-2024 | 07:33 AM
What engine ? Maybe #8 in the attached:
https://www.marineengine.com/parts/m...100JS/1939_280
BillK is offline
Old 03-12-2024 | 07:54 AM
Wally's Avatar
Were doomed!
get a veneer caliper and get some better measurements of the groove on the adapter. My guess just looking at the pic is you are somewhere in the -334 to -342 range on the o-ring charts
i know this place has the square o-rings, im sure there are other places to get them as well....and it may be a custom size too.
Square O-rings
-Wally
Wally is offline
Old 03-12-2024 | 09:58 AM
Its for a 502. Ill get some measurements
Old 03-12-2024 | 10:53 AM
Amazon Amazon
BillK is offline
Old 03-12-2024 | 10:59 AM
I just looked at the picture of your adapter again. Are you sure that is the correct gasket ? Its hard to tell for sure but yours almost looks like it is made for a round "O" Ring ? Does the oring fit into that groove in the adapter ?
BillK is offline
Old 03-12-2024 | 10:37 PM
Im not sure if it is correct. Its what came out. The grove is square shaped though, not a concave like an O ring
Old 03-12-2024 | 11:58 PM
First thing I'd do is compare it to the gasket on your oil filter.
If its not the same, then I'd measure the OD and go to Walmart and find an oil filter with the same dimension gasket.
Griff is offline
