Holley 300-564 efi intake >
Old 03-15-2024 | 09:25 PM
Default Holley 300-564 efi intake
Has anyone used this efi manifold? Where did you put the AIT (air inlet temperature) sensor?
BigDawgChallenge is offline
Old 03-15-2024 | 11:32 PM
Rookie's Avatar
Mine are in the back of the intake under the throttle body. I believe I drilled and tapped the intakes for them.
In a NA build I don't believe they are critical. I have friends that have them laying on the intake.
Boosted application is a different story.
What ECU are you running? Do you have the intake yet? I'm going to be removing mine and go HI-RAM style.
Rookie is offline
Old 03-16-2024 | 12:00 AM
Unfortunately, yes. Already purchased and installed. Im doing the holley hp.
Old 03-16-2024 | 05:17 AM
SB
How about flame arrestor base or something else just as easy ?
SB is offline
Old 03-17-2024 | 01:58 PM
I thought about going that route. I think Rookie has the right idea.
I decided to do things a little more complicated.…..because I’m and idiot.
Precision is offline
Old 03-17-2024 | 05:37 PM
I think I will be doing it in the flame arrester.
Old 03-17-2024 | 07:50 PM
SB
There you go. Me likey .
How are you going to marry the top ? Make an adapter or ?
SB is offline
Old 03-19-2024 | 04:37 PM
Yup!
Old 03-19-2024 | 08:27 PM
Tinkerer's Avatar
Precision
did you build that intake from two different ones?
How much to make me one?
what are the dimensions?
Tinkerer is offline
Old 03-19-2024 | 08:38 PM
Originally Posted by Tinkerer
Precision
you need this base and then buy the holley top.
https://www.cjponyparts.com/edelbroc...xoCdwkQAvD_BwE
sutphen 30 is offline
