Thunderbolt IV 2 mystery wires I can’t remember >
Thunderbolt IV 2 mystery wires I can?t remember
Old 04-01-2024 | 05:27 PM
Default Thunderbolt IV 2 mystery wires I can’t remember
I have two wires I can’t remember the home for.
on my carb’d thunderbolt ignition engine. 454
one black wire out of the bottom of the dizzy ( pictured )
one orangish colored wire leaving the thunderbolt box where does it live?
thanks guys!!
87CigCafe is offline
Old 04-01-2024 | 05:54 PM
Default Part number
Part number on the thunderbolt box is 5k27A v8 HP
Old 04-01-2024 | 07:23 PM
SB
SB is offline
Old 04-01-2024 | 07:56 PM
Default Also these…
Also trying to figure these out my dummy self didn’t take photos of them before they came off…. Why the difference and which wire goes where as I only have 2 wires in each engine harness one is light blue other is brown with maybe a white stripe…
Old 04-01-2024 | 08:21 PM
big sender is for oil pressure gauge,light blue wire,other sender is low oil pressure warning and gets tan or tan/blue stripe wire.
sutphen 30 is offline
Old 04-02-2024 | 04:02 AM
SB
yup^^^
note below, also tan/blue wires are for audio warning.
SB is offline
Old 04-02-2024 | 06:54 AM
Mbam's Avatar
Offshoreonly Advertiser
That does not look like any TBIV connector I remember.
You will have to figure out colors from the positions in the plug. I'll see if I can find one to post a picture of.
Mbam is offline
Old 04-02-2024 | 06:58 AM
Mbam's Avatar
The top one also has a temp sender. Generally not a great idea to hang all that stuff on a nipple. They have a tendency to crack.
Mbam is offline
Old 04-02-2024 | 07:15 AM
those blue connectors need to be shrunk for them to work they are heat shrink and shrinking makes the watertight seal
boostbros is offline
Old 04-02-2024 | 07:33 AM
ok,someone at some time changed the wire colors of that connector.
the yellow wire is ground
blue is tach or - on coil
tan wire in center is coil +
