Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
resealing a Bomar hatch question >
Old 04-10-2024 | 06:43 AM
Default resealing a Bomar hatch question
So I am sick of every time it rains the underside of the hatch is wet and soaking the carpet, I removed the hatch and well lets say I opened a can of worms. Anyway one thing led to another and I cut the plexi window out of the frame since the caulk was all mildewed. I have a new Bomar gasket but what do you think is the best material to reseal in the window? I was going to use a window/bath caulk from home depot but I figured it is not the proper product for this, do I use 4200? I know if I go 5200 its never coming apart again. its a 16" Bomar hatch in a 96 Baja 252.
Joeyboost is offline
Old 04-10-2024 | 08:11 AM
Wally's Avatar
Were doomed!
If you dot have plans on ever taking it apart again, for like paint work or some sort of repairs, then use the 5200 and be done with it. If you are planning something in the future then go with the 4200 so it will be slightly easier to get back apart.
-Wally
Wally is offline
Old 04-10-2024 | 08:16 AM
I cant say I will or I wont take it apart but I want to know the option still exists lol. Those frames are not cheap if even available, I don't want to choose violence ill go 4200 LOLOL
Old 04-10-2024 | 08:34 AM
Wally's Avatar
Were doomed!
Me personally i would probably use the 5200 on the plexy to seal that up permanently...the rest to seal up to the boat i would use something cheaper/less permanent in case you wanted to take it apart later.
-Wally
Wally is offline
Old 04-10-2024 | 09:46 AM
MY fear is the foam rubber weather seal slips over the metal frame and is sandwiched by the plexi, if down the road I ever need to change that seal again i most likely will not be able too if its got 5200 on it. What was there I scraped out with a jeweler screwdriver so it for sure wasn't 5200 or even 4200 from factory.
Old 04-10-2024 | 10:08 AM
Wally's Avatar
Were doomed!
then install the seal after the 5200 is fully cured and there should be no issues
-Wally
Wally is offline
