Kiekhaefer Trim Pump Leaking
Since late last year my trim pump has been leaking slowly into the bilge even when not in use. Looking at some other threads on here and other forums it seems like these are prone to spider cracking and I should just need to replace the reservoir. But some other people have said, "just make sure its not the cap" I have seen other other threads where people will get caps that have tubes in them and they run them into another bottle, but with where the fluid is on the reservoir I believe It is that.
I found this one on amazon and it looks like it would fit, but wanted to ask here to make sure I had the right part or if there was anything else to check.
Here are pics of the trim pump I have today in my 2003 fountain.
i didnt go to the link as stay away from opening links
as thought was getting whole pump assy,,,sry
all i use is the racing version with the deep metal canister
for that reason of the later style plastic tanks leak in time
the pump valving is lil different as tank is bolted on from bottom to the valving housing and longer for the taller tank so not a reservoir swap
there is companies that make billet reservoirs to replace the plastic and dual pumps on 1 reservior to take up less room in bildge
