HELP Flooded cabin Baja 40 Outlaw >
Old 04-16-2024 | 07:51 PM
Default HELP Flooded cabin Baja 40 Outlaw
Covered the cockpit 4 months ago with cabin door closed. Open today (prep for Desert Storm) to find 5" of stagnant water and mold growing on the upholstery.
Pumped out and removed the cockpit entry step to find a compartment filled with water and a floating bilge pump
This is my 3rd Baja. 1st one with a sink, bathroom/shower 2004 40' Oulaw in what was pristine condition. Maybe the water tank broke and flooded?
AZBAJA is offline
Old 04-16-2024 | 09:20 PM
Craney's Avatar
You need 10 posts to post pictures.
Craney is offline
Old 04-16-2024 | 09:52 PM
jeff32's Avatar
Was it stored nose down? Any water else where? Might be cleats drains if rained hard that filled the bottom?
jeff32 is offline
Old 04-17-2024 | 06:03 AM
Was it in the water or on the trailer the last 4 months? Obviously if the bilge pump had been secured down properly it should’ve been able to keep up with the incoming water, if connected with a float switch. I like the new pumps that are a float switch and pump in one.
IGetWet is offline
Old 04-17-2024 | 02:05 PM
Yeah, stored noise is slightly down. The good news is vacuumed out and getting cleaned up.
AZBAJA is offline
Old 04-17-2024 | 02:07 PM
On the boat trailer, cleaned up now. No rain in the AZ forecast as removing it from the repair shop it sat at.
AZBAJA is offline
Old 04-17-2024 | 03:14 PM
Kefurr's Avatar
Any water getting in around the bow nav light, pop up cleats or anchor locker will only drain back to the compartment under the step/floor at the bulkhead. That bilge pump you found floating is supposed to pump any water in the front/cabin area, late 90’s they started sealing that bulkhead so that it doesn’t drain to the rear of the boat.
Kefurr is offline
Old 04-17-2024 | 03:48 PM
Buh WHY?
Brad Christy is offline
Old 04-19-2024 | 04:46 PM
bajaholic's Avatar
I realize this may be a silly question, but was the rear boat plug in or out?
bajaholic is offline
Old 04-19-2024 | 05:08 PM
jeff32's Avatar
Buh WHY?
so the oily water from bilge does not go in cabin and leave bad smells. really hard to clean when oil is trapped under cabin floor
jeff32 is offline
