Volvo 270 Outdrive and PDS bearing replacement >
Old 04-24-2024 | 10:38 AM
Default Volvo 270 Outdrive and PDS bearing replacement
Hi Guys,
I have a 75 CC Lancer 19. I've never had it on the water and I got it from a deceased estate, so got no info regarding the boat.
From various internet searches I'm pretty sure it has a 270 lower on it and I read they are all interchangeable 270/280/290. I had seen that it may also be a 275 for the year of boat also.
The boat has thru hull exhaust and a belt driven raw water pump on a 383 sbc. The original exhaust outlet thru the hull has been blocked off and has a fitting which the raw water intake hose was connected to. Not sure how well that would have worked but I'm wanting to use the original water intake through the leg. The fitting was not one of the transom style elbow fittings, it is a flat plate with a nipple on the inside of the hull for the raw water hose connection.
I do know I will need to replace the top bushing that is on the pivot tube which the water neck o-ring seals against as I can easily move the outdrive side to side and tell it's missing and or worn.
I want to basically service the outdrive and make sure everything is ok before going on the water. I am unsure if my bell housing is the type which has 2 PDS bearings, which would mean removing the engine to replace the forward one (from my research) or if it has the single PDS (fingers crossed). I will post some photos and hopefully someone will be able to tell me what I've got.
The U joints don't look too bad but once I pull the transmission I would replace them anyway.
Thanks in advance.
Lancer19 is offline
Old 04-24-2024 | 10:59 AM
Ok, so it states I can't post photos until 10 posts?
What about through tapatalk?
Lancer19 is offline
Old 04-24-2024 | 11:09 AM
Not on tapatalk.
Thought I would try from MY Album but no joy.
Lancer19 is offline
Old 04-24-2024 | 11:10 AM
Weird that the photos I tried uploading to a reply had automatically gone into my album.
Lancer19 is offline
Old 04-24-2024 | 11:11 AM
Don't mind me.....
Lancer19 is offline
Old 04-24-2024 | 11:12 AM
The boat needs a fair amount of sweat equity.
Lancer19 is offline
Once it's proven mechanically I will replace the rotten floor.
Lancer19 is offline
Old 04-24-2024 | 11:13 AM
Thankfully Lancers have no wood in their stringers.
Lancer19 is offline
Old 04-24-2024 | 11:14 AM
Not long now.
Lancer19 is offline
Are we there yet?
Lancer19 is offline
