Atf
Old 05-05-2024 | 11:22 AM
Default Atf
I know that this subject, like all subjects, have been beat to death. I want to know where I can use ATF safely. Is it Trim Tabs, out drive trim, power steering?? thanks guys!!!
Wharf Rat 1 is offline
Old 05-05-2024 | 11:29 AM
F-2 Speedy's Avatar
I would think all of the above, use type F.......
F-2 Speedy is offline
Old 05-06-2024 | 12:23 AM
I use oil in my tabs and trim pumps, but really no reason you can't use ATF. I always have a few qts of oil in the boat. I use ATF in my hyd steering and only keep a qt in the boat.
Griff is offline
Old 05-06-2024 | 08:27 AM
nocigarette's Avatar
always type F in all 3. Never had any issues.
nocigarette is offline
Old 05-06-2024 | 09:22 AM
bencini231's Avatar
When mine was rigged a few years ago steering and tabs were set up for ATF and trim uses 30w oil. I don't see any reason you can't use ATF if the system is clean and ready for fresh fluid.
bencini231 is offline
Old 05-06-2024 | 10:40 AM
Rookie's Avatar
I run ATF (non-synthetic Type-F) in the above mentioned in my Scarab because I have transmissions and my bilge is painted red, also I don't want to carry extra fluids. I do not run ATF in anything in my Bravo boat because red ATF dye stains.
Rookie is offline
