Bravo Hubs >
Bravo Hubs
Bravo Hubs
Old 05-06-2024 | 01:02 PM
Default Bravo Hubs
Guys,
So, I've got a Bravo28 on the boat now, with a sacrificial that uses this hub:
And I bought a labbed one from SickStinger that has this sacrificial hub:
It slips onto the prop shaft just fine, but obviously doesn't use the castle washer. I'm assuming it's for a higher HP application (?). I really wanted to test this prop last time out, but....
In days gone by, I've been able to just tap the hub out of a prop with a dead blow hammer and something to serve as a punch (usually a chunk of bar stock of an appropriate diameter). This one wouldn't come out so easily, and I didn't want to farq it up, so I didn't use my typical "sometimes you just gotta be willing to break it" mentality and stopped. A couple questions.....
Can I use a hydraulic press to remove it? I can obviously get another sacrificial hub for the prop.
Is there typically some other retaining method used to keep the prop nut from backing off? I can't imagine it would, but I figure we have castle washers for a reason, so.... If not (meaning none is needed), I can easily make a spacer/washer to lock this hub/prop in place for our next outing to test the prop.
Thanks. Brad.
Brad Christy is offline
Old 05-06-2024 | 02:21 PM
Is there any splines left at shaft after the prop? How about making a washer from a old merc hub sleeve in lathe.
JaniH is offline
Old 05-06-2024 | 02:23 PM
Jani,
I can handle that sort of thing. That's my line of work. My questions were aimed more specifically at the sacrificial component; the part that part slips into.
Thanks. Brad.
Old 05-06-2024 | 02:30 PM
it should use the old fashon castle washer under the nut
velocity john is offline
Old 05-06-2024 | 03:04 PM
That might also be a cheaper solas or michigan wheel rubber hub, those can be tight. just hammered one of those out from a solas scorpion 3blade, and damn that was stuck in there. I would not be scared to press it out.
JaniH is offline
Old 05-06-2024 | 06:29 PM
John,
There is nothing for the castle washer to engage.
Thanks. Brad.
Old 05-06-2024 | 06:45 PM
Will this work?
https://www.westmarine.com/sierra-18...caAtNSEALw_wcB
Ryanw10 is offline
Old 05-06-2024 | 07:07 PM
Originally Posted by Ryanw10
Ryan,
There is a bit of the spline sticking out beyond the hub when the prop is mounted. I guess the spline of the washer engages that remaining spline on the shaft, and provides the castle? If that’s the case, good enough for me.
Thanks. Brad.
Old 05-07-2024 | 03:05 AM
Ryan,
Thanks. Brad.
That is correct. The castle washer engages on the splines
Ryanw10 is offline
Old 05-07-2024 | 06:57 AM
Ryan,
I ordered one from Amazon last night. Should be good to go this time next week.
Thanks. Brad.
