2023 Fountain 43 NX Center Console with Quad 450's
Just Arrived! 2023 Fountain 43 NX Center Console with Quad 450's and Custom Aluminum Quad Axle Trailer... Contact Germaine Marine in Norco CA or Lake Havasu AZ for More Details.........
2023 Fountain 43 NX
A New Level Of Excellence
You’ve just arrived at the top of the line. The sensational Fountain 43NX blends luxury, performance, and style better than any center console in this size range. Fountain is synonymous with exciting top-end, controlled midrange, and a dry ride, and the 43NX more than delivers. Everywhere you look, there’s seating: wraparound cushions surround the bow, a spacious chaise lounge tops any tanning salon, adjustable bolsters inspire big water confidence, and a full-width stern bench says “Welcome Aboard”. The cabin features a queen-sized berth, privacy head, and the mini galley has a fridge and microwave. An optional Cockpit Galley adds a second onboard refrigerator, a freezer, a grill and a sink. Built for whitecaps yet at home on big water lakes, the 43NX excites with mid-80 mph top-end potential.
Features may include:
Construction
NMMA Certified
Positive Lift Hull – Double Step, Pad Keel, Notch Transom
Infused Composite Hull – Deck, Stringer System
Stringer Grid and Transom – High Density Composite, Fiberglass Reinforced
Hardware
Rub Rail – Vinyl Extrusion (Black or White), Stainless Steel Insert
Cleats – (7) 8" Heavy Duty, (4) 8" Pull-Up
Mechanical And Electrical
Bilge Pumps – (2) 2000 GPH (Bilge), (1) 1100GPH (Console), Float Switches by Ultra Safety Systems
Engine Controls – Mercury DTS, Engine Trim
Fuel Filters – Mercury
Fuel Tank – HD Aluminum, Painted for Corrosion Resistance, EPA Compliant
Batteries
Amp Battery Charger – 50 and 36 Amp
Charging System – All Batteries, Automatic
House Battery (1) – “4D” Deep Cycle, with 110 Volt
Remote Battery Switches (5) – On/Off
Lights
Cockpit Courtesy, LED
Navigation, LED
Spreader (4) – On T-Top, Forward (2), Aft (2)
T-Top Light Bar – LED, 10K Lumens
Dash
Air Conditioning – Supply Vents (3), with Booster Fan
Panel – Carbon Fiber Reinforced
Steering Wheel – Stainless Steel, Leather Covering with Knob
Switches – Push Button, LED Indicator Lights
Cockpit And Fishing
Aft Bench Seating – Triple Wide, Padded Backrest, Storage Underneath
Aft Facing Seat – Articulating Arm Rests, Upholstered
Bow Handrails – Recessed
Bow Seating – U-Shaped, Storage Underneath
Cabin
Air Conditioning – Reverse Cycle AC and Heat
Berth – Queen Size Mattress, Comforter, Pillows
Countertops – Solid Surface
Galley – Microwave, Refrigerator
Electronics
Displays – Dual, GPSMAP-8616, 16?
Domed Radar – GMR 24 xHD Radar
VHF Radio – 215 AIS with Antenna
Transducer – Airmar B175H
Audio System
Fusion 770 Series Media Control Center
Amplifier – 800-Watt, 8 Channel, Marine Class D
Amplifier – 600-Watt, Mono Block, Marine Class D
Amplifier – 200-Watt, Mono Block, Marine Class D
Call me anytime! Boat is located in Newport Beach, CA - 949-526-6878 CHASE
2023 Fountain 43 NX
Construction
NMMA Certified
Hardware
Batteries
Lights
Navigation, LED
Dash
Cockpit And Fishing
Cabin
Electronics
Audio System
