Sierra HI-PERF oil for Bravo 1 drive. >
Old 05-17-2024 | 02:50 AM
Default Sierra HI-PERF oil for Bravo 1 drive.
Hello. Is this suitable oil for Bravo1 drive?
marko84 is offline
Old 05-17-2024 | 05:56 AM
jeff32's Avatar
Curious to read the answers!
jeff32 is offline
Old 05-17-2024 | 06:59 AM
Savings not worth risk to me. Merc/Quicksiler more money but not much. May be same stuff but I don’t like worrying about it. Only changing it once a year. New drive is 2k-4K if you change it yourself depending on what you have. JMO
liberator221 is offline
Old 05-17-2024 | 01:43 PM
You need to look at what spec oil the drive requires and compare that to the spec of the oil.
There should be better information somewhere on that bottle.
Markus is offline
Old 05-17-2024 | 03:04 PM
Quicksilver 85W-90 Extreme Performance Gear Lube is the best stuff you can use in a bravo 1. Sold by the gallon online for short of $100
CheckmateScarab is offline
Old 05-20-2024 | 03:14 PM
Mercury just buys the oil. So does Sierra. If the Sierra meets the specifications, use it.
The best gear lube is probably the Volvo synthetic. It is priced accordingly.
Markus is offline
Old 02-09-2025 | 01:21 PM
Default Had bad luck with sierra gear syn blend
Seen it trash light duty cruisers with bravo 3's and 2's. Same shop in South Lake Tahoe would put it in Volvo DP's and any bravo. And shortened the life of the cone clutch in both. Drives were slipping going into gear right before they failed.
i'd spend the money on the Extreme syn (Merc) for any bravo. And run Full syn GL-5 in the volvo. I get GL-6 full syn for a customer with a Imco SC and 600hp and been running no issue on his 26ft Fountain 8 years later.
stick with what the drive calls for, $20-40 savings on gear lube with cost thousands later.
Mod v sleek is offline
Old 02-10-2025 | 12:51 AM
Again, Sierra follows the same specs as the OEMs. As long as it is the right spec, it should do the job just as well as the OEM oil.
A lower unit is a very good place for a synthetic, as Mod points out.
Even in outboard lower units, I run Volvo Penta-spec PAO-based synthetic.
Markus is offline
Old 02-10-2025 | 05:31 AM
Just run the merc oil for a few bucks more so you don't have to worry about it.
underpsi68 is offline
