Washer stack sequence >
Old 06-15-2024 | 11:57 AM
Default Washer stack sequence
Hi,
What's the proper.proper stack
on these showers foe my Bravo One XR Sportmaster? This is the way they came off, but doesn't mean they're correct.
. The two same diameter ones, one is slightly thinner than the other. Didn't put calipers on it, but can tell.
Thanks!
imartin is offline
Old 06-16-2024 | 08:18 AM
The bellvue washer should be in the middle, not the end. In other words the washer that has a curve in it should be in the middle.
sonicss42 is offline
Old 06-16-2024 | 08:19 AM
The washer that is not “flat” goes in the middle. I can take a pic of the instructions if you need that.
Old 06-16-2024 | 04:04 PM
Thanks guys! Yes pic would be great!
Found the drawing in manual...
imartin is offline
