Foamy drive oil
Old 06-18-2024 | 10:07 AM
Default Foamy drive oil
I am running B-Max drives. I had the drive oil changed out and they used the amber looking Merc brand. Now my drive oil is foaming up in the reservoir. What can be causing this?
David H is offline
Old 06-18-2024 | 02:22 PM
Personally, I wouldn't use the regular Merc gear oil. Mercury developed the high performance lube because the regular gear lube wasn't good enough and they were eating Bravo drives when they were developed in the late 80's. I think the general rule of thumb is use the high performance lube at minimum on anything over 75 horsepower. And I didn't mistype that, seventy five horsepower.
At minimum switch to the blue stuff or find what other BMax guys are running. Amsoil? or something along those lines I suspect is probably more normal
VetteLT193 is offline
Old 06-18-2024 | 02:36 PM
VoodooRob's Avatar
As of the past couple years Merc Drive lube has been marketed as: "High Performance" is the standard drive lube for Alpha and Bravo 1. "Extreme Performance" Quicksilver is the exact same lube as "Mercury Racing" just different packaging for retail sales. Both recommended for XR and Up, High Hp Applications.
VoodooRob is offline
Old 06-18-2024 | 02:51 PM
jeff32's Avatar
I sent one of my bravo drive for a total inspection, opening the drive, changing whatever was needed.. after all my drives were not checked or open in the last 13 years!
result was: nothing needed to be changed! Been running synthetic 75-90
the only thing they told me was
NEVER USE SYNTHETIC OIL in these drives! Like never never! Not good for the drives, too thin and so on...
not sure why they put the emphasis on that... remember i ran them 13 years without any issue! I dont understand that... so i switched back to merc hi perf 85-90...
i hope they dont blow up !!!
jeff32 is offline
Old 06-18-2024 | 04:11 PM
I'm pretty sure Merc High performance lube is synthetic.
Old 06-19-2024 | 08:12 AM
Active Streak: 30 Days
^^^^^ Huh?
Helmwurst is offline
Old 06-19-2024 | 10:18 AM
BBYSTWY's Avatar
I would check and see what's supposed to be run in a BMAX....I could be wrong but I thought I remember reading that one of these aftermarket type drives ran motor oil instead of gear lube...can't remember if it was BMAX or something else entirely but that would explain the amber colored oil if that's the case....regardless it clearly doesn't like what's in there so I would either not run it or be super easy on it until you get this resolved. I'm thinking it's probably a cavitation type issue causing the foaming...same as when you run a crankshaft through your pan and the oil is too high and it starts foaming the oil...just a guess but like I said I would figure out what oil is recommended by them and change it immediately if it's different than what's in there.
BBYSTWY is offline
Old 06-19-2024 | 11:15 AM
jeff32's Avatar
Originally Posted by Helmwurst
^^^^^ Huh?
wrong tread my bad...🤦🏻‍♂️
jeff32 is offline
Old 06-19-2024 | 04:34 PM
DRAG's Avatar
Funny this topic came up, I had foamy **** in my reservoirs this weekend. I have always run the Merc Racing gear oil and I change it every 40 hours. Its always looked good, my drives look great, and I run my boat hard. I have just changed my gear oil and used the same Merc Racing lube, but I thought it looked a little different. Kinda had me questioning it. I have maybe 8 hours on it right now. I went out for a hard run, full throttle for 20 miles or so. My alarm came on for a drive lube indicator. I checked and it was all foamy in the reservoir. I topped it off a bit and went back to running but its definitely foamy and I've never noticed that before. I cooled it off the rest of the weekend becuase I had my family with me, but it was still foamy when I put it on the lift before I left. I'm gonna switch to something else like Redline.
DRAG is offline
Old 06-19-2024 | 11:28 PM
For B Max drives, I’d use the Bravo Shop Neo gear lube or the Merc Racing/QS Extreme Performance
Griff is offline
