Mecury/Merc Bravo One Impeller Kits VS Sierra water pump Kits? >
Old 06-18-2024 | 03:39 PM
Strip Poker 388's Avatar
Rob
Question Mecury/Merc Bravo One Impeller Kits VS Sierra water pump Kits?
Has anybody seen any difference between the Mercury/Merc Bravo One impeller kits and the Sierra kits?
Water pressure? not lasting as long?
Ive mainly always use the Merc kits? But the last few housings had diff markings/casting lines Etc.
I know you have to watch some dealers say it Merc then its come in a bag
Rob
PIK for looks
Strip Poker 388 is offline
Old 06-18-2024 | 04:41 PM
The Sierra one I picked up in a pinch seemed to have much softer rubber veins. They were much too easy to install. Next time out I replaced with Merc originals.
Almost every Sierra part I have bought the quality sucks
GLENAMY 242SS is offline
Old 06-18-2024 | 05:38 PM
I wouldn't risk it. OEM only...
imartin is offline
Old 06-18-2024 | 08:47 PM
seafordguy's Avatar
I just ALWAYS order mine from CPPerformance so I have a sense of comfort I’ve got genuine OEM. After almost sinking a boat when my shift cable boot that was Chinese knock off pulled off I quit trying to save money….
seafordguy is offline
Old 06-18-2024 | 10:00 PM
TomZ's Avatar
I saw lower water pressure with Sierra impellers by about five pounds. There was no negative affect on cooling.
TomZ is offline
Old 06-19-2024 | 04:34 AM
I may want to run the Sierra for the lower WP if they last as long. I would be curious if the Sierra WP falls off later. I am using a crossover with some bypass right after the cooler that dumps on top of the drive. I have plenty of water for exhaust (Lightning) and still a pretty good stream of water from the bypass to top of drive. Maybe 2 to 5 PSI at idle 20 ish at crusie and 25 at WFO. I sized my bypass when I was using the old Globe blue impellers which did produce a little less pressure.
BadDog is offline
Old 06-19-2024 | 05:47 AM
So as not to hijack this thread, the topic is different but the same- starting a new thread on Globe Impellers.
BadDog is offline
Old 06-23-2024 | 06:39 PM
I've used Sierra and I think other knock-off brands. I think the pressure is slightly lower with non-mercury but at least with my engs. it has no effect on temps. I install new impellers and housings every spring and have never had a failure with any of them.
ctuck0659 is offline
