Stock 502 carb >
Stock 502 carb
Stock 502 carb
Old 06-25-2024 | 11:36 PM
Default Stock 502 carb
I've got a stock 502 with a Holley 850 on that doesn't seem to run right, been told that's to much carb for the engine, is there a way to "detune" the carb to match up with the engine and does anyone have advice on which way to go with it?
Tom55 is offline
Old 06-26-2024 | 05:18 AM
articfriends's Avatar
A 850 is NOT "too much carb" for a 502, what it probably IS is the calibration is a total mess, especially if its a "qwick fuel" or proform etc. what brand and model carb?
articfriends is offline
Old 06-26-2024 | 05:35 AM
its a Holley 850cfm double pumper manual choke
Tom55 is offline
Old 06-26-2024 | 01:54 PM
so its NOT a brawler or quick fuel, post up the model # if you can
Old 06-26-2024 | 03:01 PM
I don't have the exactly numbers for it I will get someone to get them from the boat tomorrow and posted them here
Tom55 is offline
Old 06-27-2024 | 05:24 AM
turns out I'm wrong it's a 800cfm
model numbers are
9022
1137
Tom55 is offline
Old 06-27-2024 | 10:40 AM
so at least you dont have a chinese proform or qwik fuel. The only real way to get it correct is install a 02 on your boat, get accurate 02 readings thru out rpm band VERSUS vacuum then go after the ares its rich or lean with jetting, air bleeds, fuel passage mods, etc. I do have a mint stock 502 carb off like a 1993 502 mag carbed that is unmolested Id sell fairly reasonble. I would reccomend going thru it with new gaskets, etc as it has set for a while. Where does it NOT run right?
Old 06-27-2024 | 11:19 AM
It's sluggish getting going, last half of throttle almost makes no difference feels like it bogs and and dies back
feels down on power also it's a 24 foot speedboat and only getting up to about 55mph
the carb was previously on a 500hp but swapped over to this engine as the 500hp had cracks in the bores
Tom55 is offline
Old 06-27-2024 | 11:22 AM
F-2 Speedy's Avatar
have you checked timing, what advance are you running
F-2 Speedy is online now
Old 06-27-2024 | 11:41 AM
timing has been gone through set at 32
Tom55 is offline
