525efi no spark. Please help!! >
Old 07-06-2024 | 11:12 PM
Default 525efi no spark. Please help!!
I have a 2008 Magic Scepter 28’. It has a 525efi S/N:OM959932. I have codes: EST1 Open Circuit, EST2 Open Circuit, EST3 Open Circuit, and EST4 Open Circuit. Engine won’t start at all, and verified no spark by removing cylinder #8 spark plug. I’m confused because shouldn’t it show EST8 Open circuit if it has no spark? Please help, don’t know if it’s the ignition coils, wiring harness break, circuit breaker failure, or ECM failure.. I already checked all the fuses and tested the lanyard switch and the neutral shift switch.
Moelafify is offline
Old 07-07-2024 | 10:43 AM
your gonna have to break out the voltmeter and start probing.get a wiring diagram too.
does the tach move at all when cranking?
sutphen 30 is offline
Old 07-07-2024 | 04:37 PM
Yes the tach moves. This morning I checked for 12v at the ignition coils plugs and the red wires have power. Would that mean the coils are bad?
Old 07-07-2024 | 05:10 PM
As with all the PCM motors, to find out what the issues are you need a scanner and a manual
https://www.rinda.com/marine/marinemenu.htm
AllDodge is offline
Old 07-07-2024 | 05:16 PM
I bought the Rinda Scanner. That’s how I got those codes. EST 1,2,3,4. Don’t know how to diagnose that
Old 07-07-2024 | 05:29 PM
Need the Diagnostic manual 8M8021131
I have same issue, have twin 2023 250HP Verado and have to have "all" the manuals to figure out what is happening, which I just bought
https://www.mercruiserparts.com/bam/.../31347/13369/0
AllDodge is offline
Old 07-07-2024 | 07:28 PM
Same, I looked through the parts diagram and can’t figure it out. All fuses and relays are good. Scratching my head here
