Bravo cone clutch question >
Old 07-07-2024 | 01:43 PM
Default Bravo cone clutch question
My drives were white so I listened to the internet that it's overheating and on its way out. I replaced the drive oils and everything came out fine. No burned smell. Oil was clear. ( I replace about every 10 hrs). Yesterday I went out and my one drive was lagging going into forwards. Reverse and neutral was instant like the other side. But forwards would lag behind...fast forward through the day, we left the restaurant in the evening and boat wouldn't go into forwards at all. Again Reverse and neutral just fine....I think my question is, would this be signs of a worn clutch? Pulled it apart today to take a look and no signs of a metal or it even getting too hot. (Granite now both drives have calcium even down on the fin).
minimotox50 is offline
Old 07-07-2024 | 04:22 PM
It's the shift shaft and cone clutch matting surfaces. The fix is replace both but some can band-aid by polishing the shaft
Cooling the drives is good but most important is using correct lube
AllDodge is offline
Old 07-07-2024 | 04:24 PM
What would one suggest. I was told some vr1. 74-140
Old 07-07-2024 | 04:35 PM
Merc HP 90 is what I would use
Could also use Merc Synthetic but with a older drive it might start to leak out a seal. If it has fresh seals and not a B3 your good to go
Now using correct lube now will not fix current issue
AllDodge is offline
