2025 Statement 350 open
Waiting for our 2025 Statement 350 with trip Mercury 300Rs to be delivered. Can anyone give me some fuel usage numbers? Miles per gallon and gallons per hour. Running at certain MPH. Coming from a 33 Evolution Active Thunder with Mercury 565s. Hopefully the ride on the weekends will improve.
When I get to work tomorrow I’ll see if I can get a few minutes to pull out a previous test and get you the fuel burn numbers
when I test the boats, I usually log rpm, speed,, fuel burn, etc.
your boat is coming along nicely by the way
could u also look at 38 trip L6 350 numbers?
I won’t have that data just because we have not built one since I have worked here. We did one with l6 400’s. I’m assuming you have Garmin displays in the boat. If so, you should be able to easily setup a page that will show you the info you want for fuel burn and economy
