T u n n e l tab
Old 08-15-2024 | 10:23 PM
Default T u n n e l tab
Are all these tunnel tabs I'm seeing custom made by the builders? I was hoping to find one to test with before I spent the time to make a custom one...
im MartinB is offline
Old 08-16-2024 | 02:40 PM
MDM
Some of them are just trimtabs with an oversized aluminum plate bolted to it.
MDM is offline
Old 08-16-2024 | 05:08 PM
https://www.marineindustrieswest.com...nnelSeries.htm
VetteLT193 is offline
Old 08-16-2024 | 05:17 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
Not sure why they would call these tunnel tabs and say for V bottoms. Tunnel tabs are the width of the tunnel in cats and VERY dangerous. Even if you’re skilled enough to use one, if you lose a trim gauge it’s bad news. Forget a tunnel tab is down in a turn and you’ll end up on your lid.
WARPARTY36 is offline
Old 08-16-2024 | 11:33 PM
Totally agree on the use of these tabs. Almost turtled a twin engined 21 skater coming off speed and I forgot to bring the tab up....started to pitch severely to the starboard until I realized what was going on. Tunnel tabs is like a love/hate relationship. They work great to correct a catamarans hull design flaws or used to try to eliminate the most common cat hop. Designed one for a 30 prostock cobra that with twins 2.5s would run 92 and with trips it ran 96 then violently started to hop. Installed a tab articulated around the center engine, pull the tab down, no hop and the cobra ran 109 as a race boat. But not paying attention can get you hurt.
HuskerPerformance is offline
Old 08-17-2024 | 07:54 AM
It’s interesting to look at the different versions on the OB race cats.
when they were in cocoa some were fixed others could be adjusted.
Wildman_grafix is offline
