Drive Shower - Bravo 1 and 3 Same? >
Old 08-17-2024 | 08:53 AM
Default Drive Shower - Bravo 1 and 3 Same?
I found a used pair of drive showers off a Bravo 3 for a good price. Wondering if they are compatible before i buy.
They attach to the cylinder pin on both sides and one bolt on the top plate.
Shah Mat is offline
Old 08-17-2024 | 10:26 AM
Do the pickups run to the end and go behind the cavitation plate? if so the’ll hang way back.
The Bravo 3 has a longer cavitation plate to cover the extra prop.
The top will be fine
JaayTeee is offline
Old 08-17-2024 | 02:17 PM
Thank for the info. These appear to drop down outside the cavitation plate, just below the cylinder pin. So, if the location of the pin and top plate are the same , I should be good?
Shah Mat is offline
Old 08-18-2024 | 12:29 AM
yes
JaayTeee is offline
