Why are the trim tab hydraulic tubes so short on these K planes >
Old 08-20-2024 | 08:30 PM
phughes69's Avatar
Default Why are the trim tab hydraulic tubes so short on these K planes
Since most transoms are 3" thick, why are the hydraulic tubes for the tabs 2 3/4 when they are installed all the way? The outside of the double ended hollow stud has the plastic nut on it I can only assume for sealing. If I take the nut off and put the stud flush with the outer edge of the tab, then there is more than enough lenght inside to go thru a 3" transom and still put a washer and nut on the inside. If the stud is bottomed out like I found, then the transom has to have a recess cut into it. . Or could it be that I just have a pair of the wrong tubes? Another pair of K planes use the same length tube, so I dont think thats it.
phughes69 is offline
Old 08-20-2024 | 08:36 PM
Wally's Avatar
Were doomed!
actually most outdrive transoms are between 2" to 2-1/4"
if you have a 3" thick transom then maybe you have outboards?
either way i know there are longer tubes for the k-planes you can buy....i had to replace a set and found different sizes...call BAM im sure he can set you up or tell you the size of the threads to get some longer ones.
-Wally
Wally is offline
Old 08-25-2024 | 02:58 PM
phughes69's Avatar
Well Wally I measured and your right. My transom is 2 1/4 thick. I may have been thinking of the transom on my 38' Scarab that was 3" think
Old 08-26-2024 | 07:50 AM
Mbam's Avatar
Offshoreonly Advertiser
Stud kits at the bottom here, Mercury is sure proud of them!
https://www.mercruiserparts.com/bam/...32085/8504/375
Mbam is offline
Old 08-26-2024 | 08:10 AM
Wally's Avatar
Were doomed!
HOLY COW! $530!
I dont remember paying that much for them when i had to replace a set on some K-planes i redid....thats crazy! Almost makes ya want to go to a local machine shop and see how much for them to make a pair!
-Wally
Wally is offline
Old 08-26-2024 | 08:45 AM
Active Streak: 30 Days
Grainger or Industrial Supply???? Good grief!
Helmwurst is offline
Old 08-26-2024 | 08:52 AM
HOLY COW! $530!
Wally,
As a small machine shop owner, I can tell you they'd be about $525. Sound fair?
Thanks. Brad.
Brad Christy is offline
Old 08-26-2024 | 09:03 AM
Wally's Avatar
Were doomed!
Wally,
As a small machine shop owner, I can tell you they'd be about $535. Sound fair?
Thanks. Brad.
LMAO! I'd figure they would be $529 so you are cheaper than Merc
-Wally
Wally is offline
Old 08-26-2024 | 09:12 AM
Wally,
Whoops.... I misread (or short term memory glitched) the price on the listing. I swear I know how this capitalism thing works....
$525. And that's my final offer.
To be fair, Merc's kids gotta eat, too....
Thanks. Brad.
