Options - Replacing TRS / speedmaster II Velocity 30 Raceboat >
Old 08-26-2024 | 11:04 AM
Default Options - Replacing TRS / speedmaster II Velocity 30 Raceboat
Hi. Just starting to refit an old Velocity 30 race Deck in the Uk.
current set up 502 BBCs EFI. 72c 9 plate gearboxes onto TRS shields and upper drives. With speedmaster 2 lower. 1.5:1.
kept blowing drive shafts. So looking at which way to go with different drives. And set up. As losing the 72c the engines go further back in the boat. If going for Bravo XR or Imco etc.
anyone else done similar.
tristan247 is offline
Old 08-26-2024 | 11:13 AM
F-2 Speedy's Avatar
The Konrad's are a direct replacement for the TRS drives if you dont want to move the engines, all depends on your budget
540 Drive ? Konrad Marine Stern Drives
F-2 Speedy is offline
Old 08-26-2024 | 12:16 PM
there are options that give you way more speed for your money than sticking with a trs drive setup
Boatlesss is offline
Old 08-26-2024 | 02:16 PM
this is the sort of info I’m after ?
