Dexter Dico Titan Model 10 & 20 MC Brake Fluid >
Old 08-31-2024 | 06:33 PM
Question Dexter Dico Titan Model 10 & 20 MC Brake Fluid
I cannot find info on Dexter's nor trailer parts suppliers websites about compatible brake fluids for the disc brake model. I've been using DOT 3 but the old fluid in the MC tested off the charts for water content. Opened two sealed DOT 3 bottles I had on hand and same thing! Bought a new bottle 2 days ago removed and replaced the fluid in the MC, and today tested off the charts for water as did the remainder in the bottle! Opened a used bottle of 3-4 year old Castrol $RF DOT 4 and 0% water!!! Is DOT 4 compatible?
What brand brake fluid is everyone having success with? Prestone is one sealed container I opened and it was full of water. I find it hard to believe I need to put $75/bottle brake fluid in a trailer for it not to attract water from the atmosphere in a sealed MC.
Thanks for any insight you can lend.
Tractionless is offline
Old 08-31-2024 | 07:34 PM
Dot 3 and 4 are compatible with each other.
Been running valvaline for years in everything I own. Never tested it but never had any issues.
underpsi68 is offline
Old 09-01-2024 | 05:26 AM
Not even sure HOW a sealed container can get water absorption...suspect your testing is flawed.
Baja 252 Islander
bajaman is offline
Old 09-04-2024 | 10:15 AM
Explain how dipping a electronic tester in a fluid sample is flawed, especially considering the 3 year old open container sample tested at 0% as detailed in post #1. I say the products (like many today) are flawed, or are you of the opinion that everything you're sold new is on the up and up?
Old 09-04-2024 | 10:19 AM
I test all brake fluid I buy (now you see why) before using it and at least once a year in every braking system I own. If not at best you'll have diminished braking performance and at worst you'll rust out metal brake system components from the inside out, which can result in a catastrophic braking failure. The only reason for replacing brake fluid is due to water content, no reason to replace it at 4 years per a vehicle owners manual if it tests good. That number is simply in the manual as an estimate of when water will be absorbed into the fluid under normal usage conditions.
Old 09-04-2024 | 11:56 AM
I disagree. Fluid can be overheated also. Whenever I do a brake job, I open the caliper bleeds before pressing the pistons back in to remove any contaminated fluid.
I keep my vehicles for many, many years. I'm not saying water in brake fluid is good, but my son's car(my old car) is 16 years old now and I never checked for water. Brake system is 100% original (minus pads and rotors) with 150k+ on it. And I live in a very humid environment.
Old 09-06-2024 | 12:15 PM
Overheated fluid simply causes air bubbles to form which must be bled out. Once said air is removed, the remaining fluid is fine so long as there's <3% water in it.
You have a car with 16 year old brake fluid?
Old 02-25-2025 | 12:23 PM
MYCOTrailers's Avatar
Offshoreonly Advertiser
Hi Tractionless,
The Titan model 20 surge brake actuator manual specifies using DOT 3-4 heavy-duty brake fluid.
Best regards,
MYCO Trailers Parts. Dept.
941-748-2397
www.mycotrailers.com
MYCOTrailers is offline
