What out drive to use with 600 HP? >
Old 09-07-2024 | 07:29 PM
Default What out drive to use with 600 HP?
The new 502 engine is making around 600 HP and about the same in torque.
The boat is a 1998 Cobalt 252 that weighs 4500 lbs dry. Let's say full load and fuel 6,000 lbs.
Main use will be congested inland lake, so not many WOT runs. Mostly cruising and some tubing with the kids.
If I'm easy on the throttle, will a Bravo ! handle it? (already have a Halo max cooler)
https://www.driveshowers.com/
Will an upgraded Bravo I be sufficient? (Already have a Teague billet top cap) Maybe get the steel tower installed.
Will an XR or XZ be much better?
Don't think I'm anywhere close to needing an IMCO
Maybe just keep a spare Bravo I on hand for a quick swap in case of failure?
What's your thought?
xlint89 is offline
Old 09-07-2024 | 08:25 PM
jeff32's Avatar
I simply would not hole shot it neither catch air without managing throttle... spare bravo 1 are cheap. BUT !
id dont dont use it with respect, one simple week end could be enough to break it!
jeff32 is offline
Old 09-07-2024 | 08:29 PM
F-2 Speedy's Avatar
Im way more power than you through XR uppers and IMCO bottoms, three yrs no trouble.
F-2 Speedy is offline
Old 09-08-2024 | 06:01 AM
SB
Don’t over prop it. That causes too much throttle for planing (and everywhere else in rpm range) which loads drives way too hard. Single engine boats even more susceptible to this since weight changes (people, fuel) can more likely change the need for a prop swap. What planed fine yesterday may not with more people and fuel on board today. This is a real thing.
SB is offline
Old 09-08-2024 | 11:48 AM
Keep it in 'low gear'. Your max.speed RPM will be higher, as well as your cruise rpm a bit as well. But the drive gears won't have as much tq on them.
Tartilla is offline
Old 09-08-2024 | 10:26 PM
I have an assortment of props already.
Factory 502 (black engine) came with Mirage Plus 23p. Still have this
Have a Mirage plus 25p
Bravo I 24p
Bravo I 26p
Rev 4 22p
4 blades are prob not going to be my friend from what I'm reading.
xlint89 is offline
Old 09-08-2024 | 10:40 PM
GPM
XR or Imco SC
GPM is offline
Old 09-09-2024 | 10:51 AM
DRAG's Avatar
XR will be efficient and fast and handle the power. I crossed 210 hour this weekend and I run my boat very hard. I'm 5500 rpm all the time and always coming out of the water trying to keep up with my friends. I am either idle or full throttle literally. My fluid always looks perfect.
DRAG is offline
Old 09-09-2024 | 06:54 PM
Thank you
When going from B1 to XR, I assume it will need a HD transom assembly?
xlint89 is offline
Old 09-09-2024 | 08:04 PM
tripps's Avatar
Why do u s a y 4 blades r not gonna b e good for u
tripps is offline
