Anyone have any interest in a GM 395 cam?
This is one of those things that you had ideas to use, then plans changed and you just forgot about it till you were cleaning out the garage! I was going to upgrade the cam in my old Tahoe (like 4 trucks and some 20yrs ago!) but one thing lead to another and totally forgot about this cam till i was looking for something else in the garage the other day. I bought this used, but its a roller cam and should be good to go. No rust anywhere...it was sprayed down with i think some T-9 BOESHIELD and wrapped it up in a plastic bag and its been sitting ever since. If anyone wants it I'll let it go for $50 plus the ride. Let me know
Specs on the cam from what i can find online are:
14097395 Hydraulic Roller Design
This hydraulic roller design is used on the 383 truck and Ramjet 350 engines.
The duration at lash point in degrees (intake/exhaust) is 288/308;
duration at .050" tappet lift (intake/exhaust) is 196/206;
and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 431/451.
Valve lash is zero/zero and lobe centerline is 109 degrees.
-Wally
-Wally
