Analog trim sender for hp transom assembly? >
Old 09-27-2024 | 03:16 AM
Default Analog trim sender for hp transom assembly?
Is there analog trim sender/limit for bravo hp assy? Currently having the 3 wire sender, picture below. I need sender for analog cauge.
JaniH is offline
Old 09-27-2024 | 11:34 AM
Mbam's Avatar
Offshoreonly Advertiser
There really is not one specified but probably you could use one from a standard transom.
Otherwise there is a module to convert signal to analog
https://www.mercruiserparts.com/884359t1-module-assy
Mbam is offline
