Galvanic isolator monitor. >
Old 10-07-2024 | 04:46 PM
Default Galvanic isolator monitor.
Have a ProMariner prosafe galvanic isolator in my Formula. I was installing a TV in the cabin and when I finished i hooked up the shorepower to test. I noticed the monitor in the cabin had the "ground wire " indicator flashing "fail". Doesn't show in the picture though. Boat is at home on the trailer. I have read about being connected to a gfi outlet can cause some issues. Any idea what could be the problem?
anger mgmt is offline
Old 10-07-2024 | 07:26 PM
When I had my formula I couldn’t use the monitor on and gfi circuit had to disconnect it.
flat rate is offline
