Top Gun 500EFI’s Getting No Power >
Top Gun 500EFI?s Getting No Power
Old 11-02-2024 | 06:55 PM
Default Top Gun 500EFI’s Getting No Power
Took cover off today after boat had been sitting for a while. Put batteries in…turned on all the switches.
went to turn the key nothing. No clicking no nothing. Trim pumps work, lights work, etc. motors aren’t getting power for some reason.
checked kill switches. Checked neutral switch. Checked all fuses. Nothing.
anything else I should check. Before I start pulling dash and chasing with a meter.
it’s happening on both engines…nothing.
1MOSES1 is offline
Old 11-02-2024 | 07:21 PM
F-2 Speedy's Avatar
unplug the cannon plugs and reseat them, should be something simple ?......with the key on see if you have voltage on the starter relay back by the dist
F-2 Speedy is offline
Old 11-02-2024 | 07:43 PM
I can check those tomorrow. Given it’s happening on both it has to be something common.
We tried battery selectors on both and on engines 1 & 2.
1MOSES1 is offline
Old 11-02-2024 | 08:11 PM
F-2 Speedy's Avatar
Does your key start the engine or key on and switch on the dash to start
Old 11-02-2024 | 08:18 PM
key cycles fuel pumps.
push button start.
key isn’t doing anything at all…
1MOSES1 is offline
Old 11-02-2024 | 08:36 PM
One other thing to note…not sure of it’s relevance. The shore power inverter seems to be periodically clicking…when the batteries were hooked up
1MOSES1 is offline
Old 11-02-2024 | 09:04 PM
jeff32's Avatar
Tested your batteries individually?
jeff32 is offline
Old 11-02-2024 | 09:07 PM
yea…I used a jump pack too.
the trim pumps take a lot of power…they sounded strong when I actuated them
1MOSES1 is offline
Old 11-03-2024 | 07:19 AM
cig28's Avatar
Make sure all the breakers in the cabin are on and the red push button breakers by the battery switches don’t need to be reset.
cig28 is offline
Old 11-03-2024 | 07:25 AM
offshoredrillin's Avatar
its been a while since i put the blowers on mine, is there still a 50 amp breaker on the engines? its weird that both would pop, also all the breakers in the case where the battery switches are? push them all hard.
offshoredrillin is offline
