trouble w/ the gm 10 speed in the truck line up >
Old 11-02-2024 | 09:52 PM
Default trouble w/ the gm 10 speed in the truck line up
be careful w/ the 10 speed trans,,can momentarily lock up.
https://www.duramaxnews.com/post/mas...ecall-incoming
sutphen 30 is offline
Old 11-03-2024 | 07:51 AM
Hmmmmm
I think that transmission is a joint design with Ford.
Wildman_grafix is offline
Old 11-03-2024 | 08:06 AM
Yes, I have one in my F-150. But so far nothing from Ford regarding a TSB or recall...
Baja 252 Islander
bajaman is offline
Old 11-03-2024 | 08:45 AM
I've got a 21 Sierra with the 3.0L DMax. Shifts hard in and out of 7th under load. This explains that apparently...
madflavors26 is offline
Old 11-04-2024 | 02:24 AM
Seems the multi-speed auto trans in the perf diesel trucks are all having big issues. Often no parts available to repair.
The Ram auto trans is having issues in as little as 7500 miles.
Tartilla is offline
Old 11-04-2024 | 11:14 AM
My 2020 Ford F-150 locked up in 7th gear just as I pulled into my garage. I called the local garage near me and he re-set all the codes with his scanner, and it started working properly again.
I called Ford, and they said to bring it in cause they had a bunch of software updates for it. I took it in, got it updated, and it has been great since. I do keep my local garage number on speed dial, just in case. Once stuff like this happens, I find it very hard to gain trust back in a vehicle, but I,m slowly gaining it, since it has worked flawlessly for the past 5 months.
350scarab is offline
Old 11-05-2024 | 04:38 PM
Played golf with a guy in Carlsbad earlier this year and he has been in the transmission business over 25 years, he said everything built with the 10 speed is junk the 6 spd GM made prior is bulletproof. His shop was in the midwest and is getting calls from everyone that is blown away with the dealer prices/slow schedule when their vehicle is out of warranty.
Jupiter Sunsation is offline
