Portable generators.
Old 11-29-2024 | 04:42 PM
Question Portable generators.
My ac only pulls 700W
I was thinking HondaEU1000i
Would a larger unit like the 2000I be quieter because it wont have to idle up as much to supply 700W ?
ICDEDPPL is offline
Old 11-29-2024 | 04:57 PM
You will not regret the Honda 2000. Your AC may pull 700w but it could take 1200 at startup.
36Tango is offline
Old 11-29-2024 | 05:02 PM
jeff32's Avatar
kinda pulls 15 amps at starting and my 1000 is not enough... i would guess 2000 is the key
jeff32 is offline
Old 11-29-2024 | 05:19 PM
Thumbs up
7.5 amps at start up , so 900watts .
2000 would be better in that case .
ICDEDPPL is offline
Old 11-29-2024 | 05:28 PM
Rookie's Avatar
I run a 2000 portable. My AC rips 35 amps at startup. On my cruiser 16,000 BTU would pull 60+ amps at startup. I ran a HF Predator 3500, best generator inverter I have ever owned. It now supplies power to my 40'x50' pole barn.
Rookie is offline
Old 11-29-2024 | 05:43 PM
I have owned many Honda 2000's over the years (maybe 15?) and they are great generators. I needed one fast this past summer and bought a Harbor Freight Predator. I still like the Honda better, but the Predator is damn good for 1/2 the money.
36Tango is offline
Old 11-29-2024 | 06:48 PM
Buy the Honda 3000. It’s super quiet and will run 12 hours on a tank full. My younger brother has one he uses on his trawler that probably has 10 thousand hours plus on it and has never missed a beat.
The 2000 is great but will only give you 6 hours on a tankful running a window shaker.
tommymonza is offline
Old 11-29-2024 | 07:09 PM
I have been doing some research and it seems the internal guts for most of these are the same.
I was thinking :
Amazon Amazon
Mostly because it has cool colors lol
ICDEDPPL is offline
Old 11-29-2024 | 07:15 PM
I don`t want anything too heavy or expensive.
I`d only use it sparingly to cool the cabin while on water or maybe an overnight on the water once or twice.
ICDEDPPL is offline
Old 11-29-2024 | 07:27 PM
The 3000 gets pretty heavy. I'd opt for the Predator 2000if you want a good generator at a good price. Keep in mind, 2000 is surge (with Honda also), running watts is 1600.
36Tango is offline
