TRS SSM 2 Drives, Gimbals, Cleaver Props >
Old 12-28-2024 | 06:08 AM
Default TRS SSM 2 Drives, Gimbals, Cleaver Props
SSM 2 TRS drives, gimbals, inner transom plates and cleaver props for sale. Custom drive showers, aluminum tie bar mounts. Would like to keep the tie bar but can be thrown in upon negotiation along with hydraulic steering rams. Will also include tail housing for trannies to make them complete plug ins. Asking 6500 for everything minus tie bar and steering. Located in NJ
Nickg3130 is offline
Old 01-01-2025 | 07:54 AM
Drives/props pending. Still have transom assembly’s and inner plates.
Old 01-01-2025 | 11:02 AM
Craney's Avatar
How does a#2 drive compare to a standard Trs drive?
Craney is offline
Old 01-01-2025 | 12:45 PM
jeff32's Avatar
someone will confirm
but shorter lower I think
jeff32 is offline
Old 01-02-2025 | 05:56 AM
I saw a set of Kondrad 540 outdrives on extension boxes the other day on Crapbook. If I run across it again, Ill post a pic here. I believe it had hydraulic steering too....
kreed is offline
Old 01-02-2025 | 08:06 PM
Drives sold. Still have transom assemblys.
Old 03-07-2025 | 06:51 AM
Default Contact
I don’t have enough posts to PM/
text me 2034007450
I need back caps, rams, lines, and tie bar and saddles
NJCAFE is offline
Old 03-07-2025 | 06:55 AM
text me 2034007450
Ill shoot you a text I have some of that stuff
Old 03-07-2025 | 01:29 PM
I need cams
Stockhubshaft is offline
Old 03-07-2025 | 09:44 PM
Originally Posted by Stockhubshaft
I need cams
cams?
