7.4 MPI What spares would you carry >
Old 01-04-2025 | 02:54 PM
fastlane40's Avatar
Default 7.4 MPI What spares would you carry
7.4 MPI
Never had one of these.Any common,replaceable on the water bits.
What spares would you carry on board?Sensors etc.
fastlane40 is offline
Old 01-04-2025 | 03:00 PM
jeff32's Avatar
Originally Posted by fastlane40
7.4 MPI
I got pretty much everything that dresses the block. Shorter list of what I don't have then what I have !
jeff32 is offline
Old 01-04-2025 | 03:18 PM
I have:
  • serpentine belt
  • raw water pump (complete)
  • circulating water pump
  • alternator
  • power steering pump
  • several feet of various wire gauges
  • spare fluids for outdrive, trim tabs, engine
  • spare bilge pump with quick-connect wires
  • spare prop, hub, fasteners
Baja 252 Islander
bajaman is offline
Old 01-04-2025 | 04:07 PM
fastlane40's Avatar
Thanks for the replies.
Any known common sensor issues
Old 01-04-2025 | 04:11 PM
F-2 Speedy's Avatar
Not really pretty solid piece if maintained properly...........you might carry a cap, rotor, ignition module, plugs and a set of wires
F-2 Speedy is offline
Old 01-04-2025 | 04:28 PM
fastlane40's Avatar
Okay will add those.
Not real keen on single engine offshore boating.
Guess lots of people do it though.
Old 01-04-2025 | 04:35 PM
I've burned through a few idler pulleys on mpi's...
William Diggens is offline
Old 01-04-2025 | 04:36 PM
F-2 Speedy's Avatar
if you're running in salt air salt water cap corrosion might be an issue, and serp or V belts as mentioned above
Old 01-05-2025 | 01:20 PM
Originally Posted by bajaman
I have:
  • serpentine belt
  • alternator
In red for just an inland lake?
I applaud you.
cheech is offline
Old 01-07-2025 | 07:26 PM
TomZ's Avatar
A Rinda TechMate is needed to properly diagnose issues with these things. Without and you’re shooting in the dark. I’d want to have one of these and spare raw water pump parts on-board if it were mine.
TomZ is offline
