Continental boat trailer with drive guard 34-35’ 18,000 lb
Selling a continental boat trailer, I don’t know what year it is because I can’t read the tag it’s weathered, has a lug 3 inch tube Dexter axles so it should be a minimal rating of 6000 pounds each, that would make the trailer rated for roughly around 18,000 pounds total, this is based off research I have done because the 3 inch eight lug axle is minimal of 6000 pounds each, brakes do not work. It will need tires, but it did just make four hours of driving with a boat on it with absolutely no problems whatsoever. The trailer clearly could use a little bit of work but it’s a very good solid start if you want to do something much cheaper than buying one new for $25,000, I do not have a title for the trailer and in Ohio you do not need one. I will provide a bill of sale. You can get a weight slip certified that’s how you plate them in Ohio, if you need a title, contact your state and ask them how you would deal with that coming from Ohio without one. This is a very heavy duty trailer that just needs a little bit of love. It had a 34 foot Scarab offshore boat on it before we removed..
5250.00 cash pickup Olmsted falls Ohio 44238
