Blue Drain Plugs >
Blue Drain Plugs
Blue Drain Plugs
Old 03-07-2025 | 05:57 PM
Default Blue Drain Plugs
Hello Guys, I have a 2009 Sea Ray SLX 250 with a Mercury 496 Magnum engine, I pull the blue drain plugs total of 3 two on the right side and one on the left side, I installed the ones of the front of the engine but one on the back right side I cannot find where it goes. I should have take some photos before pulling them. anybody has an idea where it is located?
I'm gonna give it another try and see if I can find it, if not I'm going to use the earmuffs and run water though the engine and see where it comes out. Any help will be greatly appreciated.
I bought the boat about 2 months ago so I'm on the learning curve on this one, I had several boats but none with a 496 Magnum Engine.
THX!
Pete
PMCM is offline
Old 03-08-2025 | 09:15 AM
Ditch the blue plastic junk before they leave you stranded or break off in the hole. Get stainless steel replacements.
Tractionless is offline
Old 03-08-2025 | 07:29 PM
Thank You, i did not knew that was an option, I'll look for them, THX!
PMCM is offline
Old 03-09-2025 | 08:52 AM
two on impeller housing, one on cool fuel system I believe...
Baja 252 Islander
bajaman is offline
Old 03-09-2025 | 09:45 AM
F-2 Speedy's Avatar
should be one on the oil cooler
F-2 Speedy is offline
Old 03-09-2025 | 12:18 PM
look at Hardin Marine of cp performance
underpsi68 is offline
Old 03-09-2025 | 05:10 PM
https://www.hardin-marine.com/p-8108...74-5-pack.aspx
out of stock at Hardin until end of month
speicher lane is offline
Old 03-10-2025 | 04:58 PM
It literally took me a year to get those! Every single time I tried to order I got the 'out of stock' message.
Baja 252 Islander
bajaman is offline
Old 03-10-2025 | 05:11 PM
F-2 Speedy's Avatar
I bought 8 or 10 of the stainless ones from a user on here last yr.
Old 03-10-2025 | 05:15 PM
Your 496 should have 2 on the seawater pump (down low starboard side towards the front of engine), and 1 on the port side towards the front of engine on the water drain valve.
87MirageIntruder is offline
