Sudden oil pressure decrease >
Old 03-15-2025 | 10:19 PM
Default Sudden oil pressure decrease
Looking for some pointers!
I have twin 454s with 15 hours on them. They both pushed identical oil pressure at all times. After a few WOT pulls at havasu this weekend, the right motor dropped to half the normal oil pressure.
Left engine hot oil
idle @ 40psi.
70+psi at higher rpms
right engine hot oil
idle at 18psi. Sometimes as low as 15psi
40psi max at high rpm.
I replaced the oil pressure sensor, and it shows the same results. What else could have broken? Any help is appreciated!!
Jumpjets is offline
Old 03-16-2025 | 07:42 AM
jeff32's Avatar
No expert here
when you say oil hot
how hot is hot?
180 degrees? 200? 230?
but 70 plus pressure in a stock ish 454 I have never seen that b fore
although 40 is not so high either
i would test reality with a mechanical gauge if you can
i am sure some motor guru here will chime in and share their thoughts
jeff32 is offline
Old 03-16-2025 | 08:43 AM
I would take the lower pressure engines oil filter off and cut open for inspection.
underpsi68 is offline
Old 03-16-2025 | 08:54 AM
SB
Time to call the engine builder and see what the nexts steps he wants you to perform.
Hopefully this book does not appear in the mail
SB is offline
Old 03-16-2025 | 04:19 PM
You could have some oil pump issues.
The relIef spring may have partially failed.
Your oil is hotter for some reason, dropping viscosity and dropping oil pressure
Oil pump pickup blockage?
Oil cooler blockage?
Fuel dilution of the oil?
Best COA as mentioned, is to check oil and filter for contaminants.
Tartilla is offline
Old 03-16-2025 | 06:34 PM
And do this before you run it even another second. Could be something as simple as a stuck relief valve in the oil pump or it could be . . . . . . .
BillK is offline
Old 03-16-2025 | 07:01 PM
Thanks for all the quick replies!
I poured some oil out of the old oil filter, and it had more glitter than a stripper's eyeshadow. I was hoping that the oil filter was clogged, and that was causing the pressure to drop. It looks like that engine is properly f@#$ed. It has about 45 minutes of run time after the issue started. It never lost power, got hot, or made any ticking noises. I think a bearing has partially failed. I'm pretty damn impressed that it remained up on plane and making power with that type of failure.
Since there isn't a catastrophic failure, I'll yank the motor and clean it/rebuild it with the same internals. It should just need a good cleaning, new bearings, rings, and gaskets. I don't want to upgrade anything and have asymmetric power.
Jumpjets is offline
Old 03-16-2025 | 07:29 PM
F-2 Speedy's Avatar
Did you build the engines ?
F-2 Speedy is offline
Old 03-16-2025 | 07:36 PM
I did not personally build them. They were built by a performance shop in Washington, NC in 2016. I bought the boat in 2022. I already asked the previous owner, and there are no blueprints or tech data on the motors. They were built in a handshake deal, probably on a tight budget. They supposedly had 15 hours on them when I bought the boat.
Jumpjets is offline
Old 03-17-2025 | 06:56 AM
TomZ's Avatar
Depending on what you find, you might need to prepare to do both, sorry to say.
TomZ is offline
