Oil Cooler 3"x30" with fittings and mounts >
Old 04-12-2025 | 05:27 PM
Default Oil Cooler 3"x30" with fittings and mounts
Its a good used oil cooler, no engine failures. I removed this one when the matching one on the Port Side started leaking oil into the water. I pressure tested THIS one to 150psi air and no leaks . But because I could not find a matching one, I bought 2 new ones from Hardin with steering coolers built in to simplify the plumbing. Anyway, I held on to this one for a few years thinking I would find a use for it, but it never came. So moving it on if someone else could use it. $100 plus the ride
whodathought38SS is offline
Old 04-13-2025 | 11:03 AM
Hey if you still have this I am interested, just need to check my boat to see if it will fit.
496blower is offline
Old 04-13-2025 | 11:04 AM
What size an is that
Old 04-13-2025 | 01:00 PM
Oil cooler thread measures 7/8" OD the A/N fitting that goes on it takes a 1" wrench. I was running -12 hoses
Old 04-13-2025 | 02:12 PM
Hey sounds good, I think I got some valve covers from, anyways I will take it, let me know shipping to Bellingham wa 98226, let me know how to pay you and I will do it, thanks Andy
Old 04-13-2025 | 03:15 PM
Sent you a PM for the shipping cost and details.
Old 04-13-2025 | 05:08 PM
I believe -10 uses 1" wrench.
underpsi68 is offline
Old 04-13-2025 | 05:25 PM
Hey sent cash and emailed you address,thanks
Old 04-14-2025 | 01:07 PM
These are sold. Thanks
