Hp500 gil/hardin manifold plumbing help >
Old 06-12-2025 | 09:24 PM
Default Hp500 gil/hardin manifold plumbing help
I'm in the process of finishing my 89 mag 454 on a stand and have installed a used set of gil/hardin stock hp500 style manifolds that have mercurystyle plumbing. Im having some issues figuring out the thermostat hoses. Boat has been converted to crossover cooling but im looking for the hose/fitting combo that hooks up and doesn't interfere. Do i need different manifold fittings? Fo i need hp500 hoses? If i make them tight they interfere and have unnatural bends. If i make them loose they are floppy and not right. I can't cut because they are stepped/flared. See pics below. First Pic is about what it started as. Next couple are what I'm working with. Send me some pics of stockist setups and part numbers.
Summer89 is offline
Old 06-13-2025 | 03:30 AM
SB
Whilecwaiting for other responses, see if this helps:
https://www.hardin-marine.com/Instru...20-901180i.pdf
SB is online now
Old 06-13-2025 | 05:24 AM
I saw the hoses in that pic. But is there a pn for them?
Summer89 is offline
Old 06-13-2025 | 02:07 PM
In this application, you should do away with the traditional merc plumbing and use the GB style manifold plumbing which plumbs from the bottom of the water tree instead of the front to avoid the interference you are running into.
I don't have enough posts to post a link, but go to the Hardin Marine website then under product categories go to
Exhaust Systems→ Hardin Marine Exhaust → Gil Replacement Systems → Hardin/Gil Replacement Parts → Standard Hardin Marine/Gil System Replacement Parts
There will be an exploded view with part numbers for all the components on the bottom water tree.
LSXCJ is offline
Old 06-13-2025 | 02:23 PM
I was looking at that a bit. It seems like it would work well on the one side. But the other side with the alternator and steering pump it still seems like everything wants to interfere. You're talking about iten
Summer89 is offline
Old 06-13-2025 | 02:34 PM
I would run a 90 degree fitting into bottom of #7A and run a longer hose from the thermostat housing to that 90 degree fitting.
LSXCJ is offline
Old 06-13-2025 | 02:36 PM
90 degree fitting that would go into 7A would be P/N: 540222110
LSXCJ is offline
Old 06-13-2025 | 02:44 PM
Yeah I have a few extra 90s laying around. Do you by chance have a picture of one all set up with my style alternator and steering mounting?
Summer89 is offline
Old 06-13-2025 | 03:19 PM
Unfortunately this is all I can really find.
LSXCJ is offline
Old 06-13-2025 | 03:29 PM
Yeah my hose does not want to go under the power steering pump at all. I wonder if somebody took it and flipped it. Or if there's a part number of that hose that would be great
Summer89 is offline
