1998 Checkmate 251 Convincer >
Old 06-13-2025 | 03:36 PM
TYPHOON's Avatar
Default 1998 Checkmate 251 Convincer
Friend just bought anniversary addition boat with a Merc 500 HP. The boat has a crazy porpoise at 30-50 MPH. Is this common? What should he be looking for to fix the problem. Using a Hydro 4 blade PX. The only way to get it better is to use tabs and negative trim but that isn't enough to make it smooth. I had this same boat and it didn't handle like this. Mine was also a 253 version. Help please.
Randy
TYPHOON is offline
Old 06-13-2025 | 03:48 PM
What prop did you use with yours? The P5X is a bow lifting prop. Is that what Checkmates like?
Padraig
Padraig is offline
Old 06-13-2025 | 09:09 PM
The 251 likes to porpoise under 40. On mine I didn't use any trim until 35. Even at 35 just a little trim. On smooth water id trim it up a bit, feel the speed pick up and you could feel it get on top of the water, but the smallest ripple would start a porpoise session. Once I was over 40, you could trim more and more with speed.
I ran both a Hydromotive 4 blade (Quad IV) and a Bravo 4 blade. I liked the Bravo a little better because of the mid range drivability, but got my top speed with the Hydromotive. I don't think I had the extreme porpoise you are describing with my props though.
As stated above, if that's a bow lift prop, not good on the 251.
Shah Mat is offline
Old 06-14-2025 | 09:28 AM
My buddy has a 251 convincer, his hops bad without a bunch of trim tab. These boats need the big trim tabs. They are a fast hull and built well.
hpmaniac is offline
Old 06-14-2025 | 09:47 AM
Does the 251 have a pad???
Padraig
Padraig is offline
Old 06-14-2025 | 12:06 PM
Padraig
yes
Shah Mat is offline
Old 06-14-2025 | 12:42 PM
Originally Posted by Shah Mat
yes
Might be better off with a hydromotive P5 instead of the P5X. Talk to Tom at Hydromotive. Good guy and knowledgeable.
Padraig
Padraig is offline
Old 06-15-2025 | 02:03 PM
TYPHOON's Avatar
Padraig
When I had mine, they only had 3 blades LOL
TYPHOON is offline
Old 06-15-2025 | 02:11 PM
TYPHOON's Avatar
Was he running the merc big tabs or short? HE did a little testing yesterday playing with the tabs but has to drop them almost all the way down and full negative trim under 40-50 on calm water. Are these boats known for having hooks in the bottom? When you get it up to speed and start to raise the tabs and drive it gets better.
Thanks for the advice
TYPHOON is offline
Old 06-15-2025 | 04:43 PM
Rookie's Avatar
I was just going to say, throw a Mirage + on it.
Rookie is offline
