notched transom >
notched transom
notched transom
Old 07-06-2025 | 01:32 AM
Veteran: Reserves
Default notched transom
For a better understanding of the hydrodynamics of high-speed powerboats, I kindly ask for your answer:
There's no doubt that a notched transom helps achieve higher speed, but I'm interested in exactly why. I don't buy the explanation about calmer water — it doesn't really hold water.
1.) A notched transom helps achieve higher speed because it shifts the center of gravity of the planing surface further aft, requiring less trim. This allows for the use of a propeller that lifts the stern, resulting in a higher-riding boat and thus less drag.
2.) Let’s say we have a powerboat that already has sufficient bow lift even without a notched transom. In this case, does a notched transom still help achieve higher speed?
3.) When does a notched transom have just the right depth?
plavutka is offline
Old 07-06-2025 | 08:54 AM
maybe less wet running surface,so a slight less drag scenario.
sutphen 30 is offline
Old 07-06-2025 | 01:15 PM
I've always tried to have longer hull lengths for better rough water performance.
If you have hull length to spare, not such a big deal.
Same factor with hulls that have very short pointy bows. (Not the Fountain Beak) Not a lot of workable hull in the water, or the attitude of the hull is lower when it does make contact. Why some shorter hulls are able run with larger hulls is likely due to how similar they are in the aft 2/3s of the hull shapes.
Tartilla is offline
Old 07-06-2025 | 01:29 PM
The faster a hull moves through the water...the more the Dynamic COG moves aft.
A transom notch does't cut back the entire transom wetted surface, or the trim tab locations. So the "hinged" point of movement likely splits between the notch and the transom.
Any turbulent water the shears of the transom has a bit more time to recover. At 60mph, water shears off the transom at 4° rise. Faster = shallower rise. It's a time vs distance factor.
The drives need to be raised on a notched transom, just to keep them at their at transom propshaft depth.
All hulls are different. Stepped hulls even more so. Tuning requires an i dividual assessment. How much rocker is on the hull? Where is the staric COG?
It comes down to not creating a scenario where forces are competing to stabilize the hull. Obvioulsy, that's impossible all fonthe time with all of the variables, but the intent is to minimize the issue.
Don't solve the symptoms, solve the problems.
Tartilla is offline
Old 07-07-2025 | 12:29 AM
If notched transoms increased speed by anything significant, then wouldn't all performance boat companies use them??
Whether they help, hurt or do anything depends on the make of the boat.
Griff is offline
Old 07-07-2025 | 12:47 AM
Veteran: Reserves
Of course, it contributes to higher speed — I don't doubt that at all.
It's not about building or filling in a notched transom; I'm interested in the details of why and how it works.
I understand and believe everything written above, except for the part about "cleaner" water. That doesn’t make sense to me, because, for example, a stepped hull is supposed to glide over a layer of water foam — and if that’s true, that foam doesn’t just disappear immediately behind the stern. Stepped hulls can be very efficient...a nd a surface-piercing propeller is essentially operating within an air-enveloped flow anyway.
Hypothetically speaking, for whatever reason, without a notched transom on a hull with a pad keel, you can achieve enough bow lift to use a propeller that lifts the stern — for example, a 5-blade cleaver.
Would a notched transom still be beneficial in that case?
And does anyone know how the depth of a notched transom is determined numerically? I know, light transom-deeper notch..., but in details?
Apologies if I'm being a bit persistent, but I'm genuinely fascinated by the hydrodynamics of planing boats and would really like to understand it as thoroughly as possible.
plavutka is offline
Old 07-07-2025 | 11:19 AM
Wally's Avatar
Were doomed!
I may get some chit for this but in my mind a notched transom is nothing more then a cheap way raising the X-dim without putting standoff boxes on the boat. It potentially can net some higher speed if properly dialed in...but what mfg is going to take the time to dial in every boat that's made for optimal performance unless its a race setup? Keep in mind that unless its a cookie cutter boat like a bayliner that get mass produced..custom boats are not all built the same. So what may be fast on one boat may not be as fast on the same boat built at a different time...
There are people who have installed notches on their boats after the fact and it has worked...but most are basing the notches on other models of the same family where they can start with a good baseline.
If you don't all-ready have a notch then get standoff boxes.
If you do have a notch then i would ask others with the same boat for setups as a stating point to help dial it in.
But i don't think i would take on the task of putting in a notch in a boat that never had one....unless the transom is gone and needs to be replaced and the boat was either free or its your dream boat that you just can get over letting go
-Wally
Wally is offline
Old 07-07-2025 | 11:40 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's not so much to raise X-dimension. It's to set the props back, in "smoother" water. It's basically a cheap setback box.
Search "35 Sonic porpoise" here on OSO. It's notorious for the porpoise issue BECAUSE of the notched transom. The boat gets on plane, and as you trim out, it starts to primarily use the back of the hull. And then it "runs out" of hull and the nose drops. Then this process repeats.
You have to either drag the tabs when in the higher RPM range...
...or get drastic and fill the notch back in (which was done on a few boats).
Sydwayz is offline
Old 07-07-2025 | 12:47 PM
Veteran: Reserves
Looking from a distance, I think the biggest advantage is that during fast planing the bottom go higher out of the water and because of the notch the drive is suddenly further back of the base center of grawity and the engine can even look over this new stern, which at that moment shifts the center of gravity back, which greatly improves the trim. Maybe even so much that you can put a clever propeller up and lift the whole speedboat higher, which in the end really helps a lot to higher speed. Without the notched transom it is probably not possible to do this because the drive would need too much trim, which is not the case with the clever and you dig deeper in the water.
So the notched transom indirectly helps to higher speed.
Am I right?
plavutka is offline
Old 07-07-2025 | 07:19 PM
A notched transom can increase a boat's speed, but the effect depends on the boat's design and operating conditions. Here's a concise explanation:
  • Reduced drag: A notched transom allows water to flow off the stern more cleanly, reducing turbulence and drag compared to a flat transom. This can improve hydrodynamic efficiency, especially at higher speeds.
  • Lowered engine height: The notch often allows the outboard motor or lower unit to be mounted higher, reducing the wetted surface area of the gearcase in the water, which further decreases drag.
  • Improved planing: By altering the flow of water at the stern, a notched transom can help the boat plane more quickly, reducing resistance and allowing higher speeds.
However, the speed increase isn't universal:
  • It’s most effective for high-performance or lightweight boats (e.g., bass boats, racing boats) operating at high speeds.
  • For heavier or displacement hulls, the notch may have minimal impact or could even disrupt stability if not designed properly.
  • The benefit depends on proper setup (propeller, engine height, and weight distribution).
Studies and boater experiences suggest a notched transom can add 1-5 mph in some cases, but real-world gains vary. If you want specifics for a particular boat, I can search for relevant data or analyze posts from boating communities on X. Would you like me to do that?
ICDEDPPL is offline
